All Forums  /  Experienced Deep Sky Imaging  /  NGC 6888 Cresent Nebula in SHO hubble, or HOO?
Started by rharris on 6/1/2024 7:04:02 AM CST
Posted 6/1/2024 7:04:02 AM CST
I spent 15 hours on NGC 6888 the Cresent nebula using my Takahashi FSQ-106-EDX4 and a ZWO 2600MM.
My acquisition details are below:
Sulfur II: 18 frames at 300s each = 1.5 hours
Hydrogen Alpha: 88 frames at 300s each  = 7.3 hours
Oxygen III: 50 frames at 300s each = 4.15 hours
Red: 10 frames at 180s each = .5 hours
Blue:  10 frames at 180s each = .5 hours
Green:  10 frames at 180s each = .5 hours
Total acquisition time = 15 hours
Final image and all here: https://ozarkhillsobservatory.com/ngc-6888-crescent-nebula-captured-with-takahashi-fsq-106edex4/
When I was processing I realized some pallets have more clarity than others and I see several different choices by astrophotographers on this subject, but I'm torn.
Ultimately I chose HOO (Ha=red,OIII=blue, OIII=green) and then used RGB for my stars.
But see below, the same closeup starless image of the nebula itself, one in HOO and one in Hubble pallet (Ha=green,OIII=blue, SII=red).
Thoughts?
Posted 6/1/2024 10:23:59 AM CST
I thought I would also add the "final" image here for comparison. (lower quality)
Free Resource of Binocular Targets
Started By jty.astro on 8/26/2026 6:25:45 AM
Nearly Perfect Finder Scope
Started By jty.astro on 8/26/2026 6:13:38 AM
