All Forums  /  Astrophotography and Sketching  /  M27 Dumbbell Nebula with a Takahashi FSQ106EDX4 instrument
Started by rharris on 7/13/2024 4:20:50 PM CST
Posted 7/13/2024 4:20:50 PM CST (Last edited 7/13/2024 4:21:35 PM CST)
I finally got around to fully processing 4 hours of data from the Takahashi FSQ106EDX4 on the M27 Dumbbell nebula.
The full details of the shot are here:
https://ozarkhillsobservatory.com/m27-dumbbell-nebula-with-a-takahashi-fsq106edx4-instrument/
Summary:
Date: July 2nd, 2024
Direction of Observation: East 90.3 degrees, Alt =  +17 degrees
Telescope: Takahashi FSQ-106EDEX4 at 530mm, F5
Mount: ZWO AM5
Camera: ZWO 2600MM (monochrome), Temp= -20, Gain= 300 / ZWO RGBL + SHO filters
Guide Scope: Williams Optics 50mm
Guider: ZWO ASI 120 mini
Controller: ZWO ASI Air
Acquisition:
Sulfur II: 7 frames at 300s each = 35 minutes
Hydrogen Alpha: 7 frames at 300s each  = 35 minutes
Oxygen III: 7 frames at 300s each = 35 minutes
Red: 5 frames at 300s each = 35 minutes
Blue: 5 frames at 300s each = 35 minutes
Green: 5 frames at 300s each = 35 minutes
Total acquisition time = 4 hours
