All Forums  /  Astrophotography and Sketching  /  18 hours of Veil Nebula wide field
Started by rharris on 8/9/2024 11:50:45 AM CST
Posted 8/9/2024 11:50:45 AM CST
Shot over 4 nights in the Ozarks, below is my interpretation of the data from the scope/camera combo used for 18.5 hours of data.
I'm especially impressed with the Ha footprint, which I attached the Ha stacked frame below as well for review.
Full shot details are on my website:
https://ozarkhillsobservatory.com/veil-nebula-astrophotography-over-ozark-hills/
Astrophotographer: Richard Harris
Date: August 3 - August 8th 2024
Direction of Observation: E 069° 39' 26.5" Alt +26° 51' 39,9"
Telescope: Takahashi FSQ-106EDX4 with 0.7X 645 Reducer (380 mm)
Mount: ZWO AM5 harmonic drive
Camera: ZWO 6200 MM (monochrome), Temp= -20, Gain= 300 / ZWO RGB + HO filters
Guide Scope: Williams Optics 50mm
Guider: ZWO ASI 120 mini
Controller: ZWO ASI Air
Narrowband Acquisition
Hydrogen Alpha: 85 frames at 300s each  = 7 hours
Oxygen III: 102 frames at 300s each = 8.5 hours
Red: 12 frames at 300s each = 1 hour
Blue: 12 frames at 300s each = 1 hour
Green: 12 frames at 300s each = 1 hour
Total acquisition time: 18.5 hours
Darks/Flats/Bias: (None)
Processing: Pixinsight, Photoshop over 2 days
Bortle Class Sky: 4
Posted 8/10/2024 1:40:42 PM CST
You know that moment when you started at an image for way to long during processing, and you completely missed a gradient floating over everything!? Here’s an update! Sorry for burning your retinas with my horrible gradients!
Rich
