All Forums  /  Experienced Deep Sky Imaging  /  Elephant's Trunk Nebula with my Takahashi FSQ-106-EDX4 and 2600MM
Started by rharris on 7/18/2024 7:04:59 PM CST
Posted 7/18/2024 7:04:59 PM CST
Greetings all, here to present my latest efforts on the Elephant's Trunk Nebula - IC1396 using the portable rig on the AM5.
Full details here: https://ozarkhillsobservatory.com/ic-1396-elephants-trunk-nebula-from-the-ozarks/
Elephant's Trunk Nebula IC 1396 astrophoto acquisition details
Date: July 14, 2024
Direction of Observation: East 52.5 degrees, Alt =  +30.6 degrees
Telescope: Takahashi FSQ-106EDEX4 at 530mm, F5
Mount: ZWO AM5
Camera: ZWO 2600MM (monochrome), Temp= -20, Gain= 300 / ZWO RGBL + HO filters
Guide Scope: Williams Optics 50mm
Guider: ZWO ASI 120 mini
Controller: ZWO ASI Air
Acquisition:
Hydrogen Alpha: 20 frames at 300s each  = 1.6 hours
Oxygen III: 20 frames at 300s each = 1.6 hours
Red: 5 frames at 300s each = 35 minutes
Blue: 5 frames at 300s each = 35 minutes
Green: 5 frames at 300s each = 35 minutes
Lum: 10 frames at 300s each = .8 hours
Total acquisition time = 6 hours
Darks/Flats/Bias: (None)
Processing: Pixinsight, Photoshop over 2 days
Bortle Class Sky: 4
Posted 7/18/2024 7:07:07 PM CST
Starless version here:
